A4 Indicator Relay help!!
Old Mar 27, 2008 | 05:35 AM
liquidblue22's Avatar
Default A4 Indicator Relay help!!
Hi guys
Ok the audi is:
A4 Avant
1.9tdi
1998
And to make things a little more difficault i live in the UK(so everything is probably backwards) ;-0
My problem is that whist driving this morning the indicators suddenly stopped working. The sysptoms are:
No turn signals at all or even occasional flashes
No hazard lights at all
However:
When setting the alarm the exterier turnsignals flash onceas well as being registeredon thedash display(as normal)
When parked if the parking lights still work (when the indicator arm is pushed wither up or down)
Iimmediatlly checked the fuse which is fine, so ihave guessed it would be the relay as i cant hear it clicking anymore does this sound right and if so where actuallyis it -i have found a cluster of relays under the steering wheel with white numbers on is it one of these and if it is which one...
Thanks for any help with this as im a little bit stuck with what else to do.
Old Mar 27, 2008 | 06:05 AM
techbod's Avatar
Default RE: A4 Indicator Relay help!!
prety common fault thr relay is the hazard switch so you need to replace it
Old Mar 27, 2008 | 06:12 AM
Thanks for the quick reply.....It doesnt have the triangular hazard switch but the rectagular button is it still behind this?
Old Mar 27, 2008 | 06:39 AM
Done ir.....Thanks again!!!
Old Mar 29, 2008 | 04:40 PM
A4avantQuattro98's Avatar
Hi, I was hoping to get someinfo onmy relay-related question.
I have a very similar car: A4 Quattro Avant 1998 (2.8 l engine).
and I saw techbod's earlier post with an attached photo with relay schematic:
RE: HELP - Need a wiring diagram for the starter circuit - 2/23/2007 10:33:33 AM
I was wondering if you could help me out: I've been trying to find the schematic for the relays (like the techbod's diagram, but with the list of relays for each position). My specific concern is: position 3 on my relay board is empty, and I am not sure if there should be a relay there (and if yes, which one).
Thanks. I appreciate your help and time.
iastudilloi
Sep 27, 2018 04:41 AM
Mutley1
Dec 22, 2012 09:02 AM
CrazyA4
Aug 30, 2010 02:42 PM
stevetwood
Jun 18, 2007 03:55 AM
cmr772003
May 3, 2005 08:01 AM
