A4 throttle hesitation problems
Old Jan 18, 2010 | 01:29 PM
b5rider's Avatar
Default A4 throttle hesitation problems
I have a 2001 A4 1.8t manual trans. The problem I have is throttle hesitation and uneven response from the gas peddle. It happens anywhere between 1/4 - 3/4 throttle, when I keep the throttle in the same position the car will jerk around increase/decrease accelerate all on its own. Almost like I am going on and off the throttle but I am not. I am new to these Audi's and have no clue what it could be. FYI: I already replaced the spark plugs, coil packs and cleaned the MAF sensor.
Old Jan 24, 2010 | 12:38 AM
98 a4's Avatar
get some carb cleaner and clean out the throttle body, that should do the trick if not then check your air filter
Old Mar 23, 2010 | 08:23 AM
AudibahnRI's Avatar
I have a 2010 A4 2.0T with 1500 miles. When I'm on the highway at around 80mph and holding the throddle steady, I notice a slight lunging back and forth, even though the RPM's are steady. If I increase or decrease the throddle, the lunging stops.
I also get some hesitation when it's warming up.
Maybe Audi's just do this...
Old Mar 24, 2010 | 09:05 PM
b5rider's Avatar
Thanks, I ended up figuring it out. It was a bad MAF sensor, even though I cleaned it and had no CEL, I needed a whole new one. Car runs good, for now...
Old Mar 26, 2010 | 11:54 PM
ImTheDevil's Avatar
Cleaning the MAF usually cooks it in these cars unfortunately - a little wetness from the cleaning fluid is all it takes when you power it up.
explorer686
Nov 15, 2012 11:43 PM
troysherk
Oct 8, 2012 02:02 PM
viperu27
May 6, 2007 02:37 AM
impala_man2003
Mar 15, 2007 01:19 AM
Bungaleh
Nov 28, 2006 01:43 AM
