A4 Will not Start
Ok this is my first post and I read practically a hundred similar posts in hopes of finding an exact match to my symptoms.
I have a 97 A4 2.8. I have only owned the car about 1.5 months thus far. All of sudden with no warning or other issues, the car would not start yesterday. All I get is a single click when I try to start it. I tried jumping it and that did not work. I could pop it (5 speed) and thus that is how I got it home. I replaced that battery but that did not fix it.
Now is where the confusing part starts for me. When you pop it, it will not hold a low idle. I could drive it all day on the highway, hence when it first did yesterday I was about 25 miles from home. As long as I was moving, it ran fine. As soon as I slow down to where it needs to idle, it stalls, then of course I can't crank it back up. So popping it in traffic was excellent, I suggest that for everyone..ha
So I have two issues, no low idle(maybe and alternator) and no starting(starter/solenoid). There is no way in h*ll that the starter and alternator went out at once. I just can't think that is what happened. So based on previous posts I am guessing maybe the grounding issue that others have had happen. Or maybe this secondary fuse panel??
Oh and the key switch and starter were replaced in 2003 before I got the car.
Any help would be most excellent...
Well I took off the Idle Control Valve and cleaned it out and put it back on. I pop started it and the idle is now fine. The starter however is another issue. I bought another one and was going to replace it, ha.. ha.. Hats off to everyone that has done that themself. I gave up.. I will be searching today for someone to put one on for me... What a PITA!
Vict0ar
Apr 3, 2014 08:38 PM
kinnes042
S4
Apr 10, 2013 06:29 PM
brit.mike13
Oct 17, 2010 08:26 PM
