A6 (C6) Coding issue or what...
Old May 23, 2009 | 08:50 PM
Tom$lick's Avatar
Default A6 (C6) Coding issue or what...
I just got an '05 A6 (C6). Has nav but didn't have a disc. I got a version 5 disc and put it in. It updated and looked like everything was fine. The maps and everything show up if I put in the start address but the system doesn't track any satellites. I don't know if the nav worked before of not. Being that the warranty just expired right before I got it and it was a lease, I'll go with the odds and say it did work. Tried the XM and it was working. Here's my scan data:
VCDS Version: Release 805.3
Data version: 20090213
Saturday,23,May,2009,18:59:24:31091
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 72 76 77
VIN: WAUDG74F45N094458 Mileage: 77020km/47858miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: None
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0020
Revision: --H15--- Serial number:
Coding: 0000000000000000
Shop #: WSC 25015 444 90125
1 Fault Found:
005495 - Right Engine Mount Solenoid Valve (N145): Open Circuit
P1577 - 009 - Open or Short to Ground
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Mileage: 77001 km
Time Indication: 0
Date: 2009.05.23
Time: 09:31:54
Freeze Frame:
RPM: 1344 /min
Mass Air / Rev.: 168.9 mg/str
Temperature: 87.0°C
Part Throttle
Load: 31.4 %
Speed: 18.0 km/h
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0093283
Coding: 0000002
Shop #: WSC 02327 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300113127
Coding: 0000011
Shop #: WSC 25614 444 57706
Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H36 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 730 E HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 360AF057514542
Coding: 0000003
Shop #: WSC 02335 785 00200
Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000024 Serial number: 00000000104243
Coding: 0524326
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013103
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBD7108359
Shop #: WSC 00000 000 00000
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 3
Reset counter: 121
Mileage: 76852 km
Time Indication: 0
Date: 2009.05.18
Time: 20:47:33
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Component: SDAR
1 Fault Found:
02633 - Antenna for Satellite Tuner
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 131
Mileage: 77000 km
Time Indication: 0
Date: 2009.05.22
Time: 19:13:25
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D086CY4
Coding: 0013622
Shop #: WSC 25614 444 58846
Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025050150377
Coding: 0002041
Shop #: WSC 02323 785 00200
Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0660
Revision: 00200000 Serial number: 4R8544E15
Coding: 2113263
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008051200032
Coding: ECFE73CC1B3904
Shop #: WSC 02325 785 00200
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H44 0740
Revision: 00000000 Serial number: 378AQ057515093
2 Faults Found:
02444 - Disk Drive Load / Eject Malfunction
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 131
Mileage: 77000 km
Time Indication: 0
Date: 2009.05.22
Time: 21:35:36
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 131
Mileage: 77000 km
Time Indication: 0
Date: 2009.05.22
Time: 22:13:46
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00000000 Serial number: # A
Coding: 0035563
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01002388670000
Coding: 0423997
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F5 910 223 D HW: 4F5 035 223 E
Component: DSP-High C6 H14 0310
Revision: PROD_01 Serial number: 00000000024591
Coding: 0000016
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000059250
Coding: 0001114
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00000000 Serial number: cCA
Coding: 0035563
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 C HW: 4F0 907 801
Component: EPB CDEC0080 H03 0080
Revision: --H03---
Coding: 0005022
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Component: AFS-Modul rechtsH05 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394AQ057510847
Coding: 0000002
1 Fault Found:
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 131
Mileage: 77000 km
Time Indication: 0
Date: 2009.05.22
Time: 19:28:17
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000007159
Part No: 4F0 915 105 C
Component: von VA0 2501260871
Coding: 344630393135313035432056413032353031323630383731
Shop #: WSC 00000 384 00290
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11720501201234
Coding: 0001206
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 A HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007512964
Coding: 0010900
End ---------------------------------------------------------------------
Old May 24, 2009 | 03:24 AM
Midniteoyl's Avatar
Navigation, Radio, Media Player, Antenna all show faults...
Is a pretty glaring reason... Theres more.
Old May 24, 2009 | 08:56 AM
Tom$lick's Avatar
Maybe I should rephrase the question. All the antenna faults showed up at the same time I put the new nav dvd in. Did the nav update somehow recode something and effect the antenna? Is this antenna powered by something or is it passive? The radio and XM sat radio work fine, the nav isn't tracking satellites.
I can read the codes. I work Avionics for a living and most of the time the problem is a software issue, I need someone with some insight but thanks for the smart *** answer anyway.
Old May 24, 2009 | 08:17 PM
Midniteoyl's Avatar
Um, I wouldnt want you working on my plane...What FBO you at so I can avoid it?
And, I wasnt trying to be a smart ***. You gave no clarifying remarks in your first post as to what you do or what you did, and you dont even know if it worked before you updated...
So, seeing the faults I saw......Where'd you start?
edit: I mean jeez... look at all the antenna faults... you think somethings disconnected?
4RingBling
Dec 5, 2013 12:11 PM
trutwin
Oct 1, 2010 01:34 PM
kchao2000
Jan 6, 2010 08:31 PM
kiberon
B7 Models
Feb 3, 2009 03:36 AM
noid73
Jun 29, 2007 09:49 PM
