A6 cat problem???
Old Jul 12, 2007 | 08:41 AM
FixOrRepairDaily's Avatar
Default A6 cat problem???
Ihave a 1999 A6 Avant quattro. I have a check engine lighton and just got the following computer code from my freinds diagnostic readed: code is P0432 - Main catalyst below threshold (bank2).
Does this mean the catalytic converter is bad or just a sensor? Are their 2 catylitic converters on this model? What does bank 2 mean? How do you determine which converter is bad if their are 2 of them?
Please advise.
Old Jul 12, 2007 | 12:24 PM
2k S4's Avatar
Default RE: A6 cat problem???
B2 is the passenger side. Yea, the cat could be going.
Old Jul 12, 2007 | 07:30 PM
SAudi's Avatar
im pretty sure bank 2 is the post cat sensor. i have the same code popup all the tie due to a damaged post cat o2 sensor, id replace it if you wanna pass OBD2 emissions, otherwise you have to take the sniffer test. the post cat is really only for the emissions.
Old Jul 12, 2007 | 08:20 PM
2k S4's Avatar
ORIGINAL: SAudi
im pretty sure bank 2 is the post cat sensor. i have the same code pop up all the tie due to a damaged post cat o2 sensor, id replace it if you wanna pass OBD2 emissions, otherwise you have to take the sniffer test. the post cat is really only for the emissions.
It's a V6, so there are 4 o2's B1 S1, B2 S1, B1 S2 & B2 S2.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
