Abs!
Old Sep 28, 2009 | 03:45 PM
ddawg's Avatar
Member
Red face Abs!
hi recently i changed my axle boot.. everything went well not a problem.. after we put it all back together and made sure it was all good, i took it for a test drive .. everything was good and smooth except for the brakes .. when i was braking at a stop sign, before i completely stopped, my ABS would turn on ... its been like that for a couple days and then stopped.. now my brake light blinks and my abs light is on... pls help!
Old Sep 29, 2009 | 11:54 PM
love the booB5's Avatar
SoCal Crew Member
dropping info: http://www.audiworld.com/tech/elec116.shtml
I have the same problem and I'm searching for an existing thread to ask about this in. I'll plug this thread again if I find a better thread for this. In the meantime, check out this site and let me know what you think about the rebuild option:
http://www.modulemaster.com/en/index.php
160 bucks plus shipping and they include a DIY... seems pretty legit. I haven't heard anything about them though and I'd like to get an idea of what their reputation is...
Old Oct 1, 2009 | 10:11 PM
ddawg's Avatar
Member
the rebuild sounds great! but i dont that thats my problem.. since it started doing that right after i changed axle boot, i think i screwed up the sensor or something cause i cleaned it today and still nothing worked...
Old Oct 1, 2009 | 10:48 PM
SoCal Crew Member
it might just be a coincidence that it started right after you changed that boot. you may have a sensor going out, but this is a VERY common problem with our cars.
I suggest you find someone with a VAG-COM and scan your car to see what those codes are from. if it throws one of the codes listed in that DIY, you know your ABS Module needs replacing or rebuilding.
Good luck man.
Old Oct 2, 2009 | 11:10 AM
ddawg's Avatar
Member
ok ill try thanks
Old Oct 2, 2009 | 12:59 PM
Midniteoyl's Avatar
I'd say look at the sensor where you changed the boot. These things need to be at a set distance from the ABS ring and clean from brake dust and crud. Since you were in there, make sure its still correct and clean.
Old Oct 3, 2009 | 02:02 PM
ddawg's Avatar
Member
where is the sensor?
Old Oct 3, 2009 | 05:40 PM
Midniteoyl's Avatar
The wheel hub.
Old Oct 5, 2009 | 03:41 PM
ddawg's Avatar
Member
wow thanks! i took it out, cleaned it with brake fluid, and it works awesome now thanks!! =)=)=)
Old Oct 5, 2009 | 03:56 PM
Midniteoyl's Avatar
Brake fluid?? You mean cleaner?
Glad it works... do the rest of them now.
