ABS active most time I press brakes. HELP!
Old Feb 14, 2010 | 03:58 PM
marches9036's Avatar
Default ABS active most time I press brakes. HELP!
Audi A4 B5 Quattro 1.8T, 2000
Hi,
Been a while since I was here. Your advise for DIY and sources for problems worked out last time and all repairs done.
I have a new one. This is something that has been going on for a while though, I did not mention this last time.
When you pres on the brake, the ABS kicks in 80-90% of the time. I.e. the pedal under the foot chatters and you here it.
Error code on report VAG - COM.
8EO614111A
ABS/EDS 5.3 Quattro D10
Coding: 0273004284
Shop: BB2434
No Fault Code.
Can someone point me in the direction.
I have read many stories about the module being the culprit every time. I found several places to fix them from $50 to $400. Some good comments and some very bad comments on service.
Is it the module or the Pump. The P/N on the VAG report 111A is for the Pump.
What do you think?
New parts from Audi are scary priced here in Canada.
I thank you again in advance.
Joe
Motorefugee
Sep 13, 2010 12:50 AM
marches9036
May 31, 2010 12:02 PM
stutzdriver
Jan 24, 2009 11:22 AM
EVOLA4
Dec 23, 2007 12:36 PM
auditt225
Aug 10, 2007 07:25 PM
