ABS wheel sensor
Old Jan 3, 2007 | 05:50 AM
SAudi's Avatar
Default ABS wheel sensor
Well my wheel bearing finally caused some erro in the right rear abs sensor, its not clearing with the code reader so ive decided to just replace the d@mn thing. the problem is i have a 1996 a4 and unlike th later models ive seen that have a bolt holding it on, this looks like its just jammed in there, anyone know how to get it out, and where i can get a cheap replacement. also i have the abs and brake light on in my dash is this normal under these circumstances.
Old Jan 3, 2007 | 08:53 AM
techbod's Avatar
Default RE: ABS wheel sensor
Installing
‒Renew clamping sleeve
‒Grease the O-ring of the speed sensor all around with lubricating paste
G 000 650 before inserting. [/ul]
Removing and installing speed sensor on rear axle
‒→ Unclip speed sensor wiring from retainers.
‒Pull speed sensor out of axle beam[/ul]
renew items 3 and 4 in the picture
[IMG]local://upfiles/12092/2B58B11FDE5F49EBB26413DA270F4E3B.jpg[/IMG]
Old Jan 4, 2007 | 03:29 PM
Coop's Avatar
lights on is normal, just tells you that your system is not functioning properly.
Old Jan 18, 2007 | 03:47 AM
SAudi's Avatar
anyone know if an abs sensor off a 1992 100cs would fit my car.
Ploplen
Dec 12, 2010 05:39 AM
srooper
Sep 6, 2009 03:42 PM
neomaxddr
Apr 1, 2009 03:16 AM
MacaveliMC
Dec 4, 2008 12:26 AM
