AHA vs AFA
Old Mar 25, 2008 | 03:39 PM
andrewk24's Avatar
Default AHA vs AFA
I am trying to buy some spark plugs and I came across a category for the A4 Quattro 2.8 V6 that separate between AHA and AFA. How do I know if my car is an AHA or AFA?
Thanks,
What's your recommendation for the spark plugs?
Old Mar 25, 2008 | 10:27 PM
AudimaniaA4's Avatar
Default RE: AHA vs AFA
This can be found in the maintenance manual. There is a sticker on the iside of the cover page.
You will also need a long socket wrench and a magned to get the spark plug out. I recently got Boch, platnum plated, and it's been working fine.
Old Mar 26, 2008 | 06:26 PM
andrewk24's Avatar
Sorry, but don't have the manual...
Thanks
Old Apr 2, 2008 | 10:18 PM
tmanning's Avatar
According to the Bentley manual, AHA is the 2.85 Valve engine. There is no listing for AFA, but AFC is noted as the 2.8 2 Valve engine.
Old Apr 3, 2008 | 03:12 PM
beefski's Avatar
Most likely an AFC, I used NGK spark plugs
NGK - bkur6et
Automotive Fitting:
Displacement
Engine VIN
AUDIA4(1996)
2.8LV6
AFC
AUDIA4 QUATTRO(1996)
2.8LV6
AFC
AUDIA6(1996)
2.8LV6
AFC
AUDIA6(1996)
2.8LV6
AFC
AUDIA6(1995)
2.8LV6
AFC
AUDIA6(1995)
2.8LV6
AFC
AUDIA6 QUATTRO(1996)
2.8LV6
AFC
2.8LV6
AFC
AUDIA6 QUATTRO(1995)
2.8LV6
AFC
AUDICABRIOLET(1996)
2.8LV6
AFC
AUDICABRIOLET(1995)
2.8LV6
AFC
AUDICABRIOLET(1995)
2.8LV6
AFC
Old Apr 3, 2008 | 04:25 PM
tmanning's Avatar
It apparently depends on the year. What year is your A4?
Old Apr 4, 2008 | 12:49 PM
andrewk24's Avatar
It's a 1998 A4 Quattro 2.8L V6 with a number 5 on the plastic engine cover. I am assuming that will be a 30V (6 x 5v).
Looking for the correct spark plug. What's the recommended oil grade?
Old Apr 8, 2008 | 04:33 PM
tmanning's Avatar
That's the same car I have. It has the AHA motor designation. I use 10W 30 in the winter and 10W40 in the summer. I do not recommend synthetic oil unless the car has always used it. The gaskets can be affected by the switch between oils (as told to me by an Audi Tech).
TBM
Old Apr 11, 2008 | 02:03 PM
andrewk24's Avatar
Thank you for the reply.. What about the plug? What plug is recommended?
Thanks
Old Apr 18, 2008 | 01:40 PM
tmanning's Avatar
They use both Bosch and NGK.
