Quattro heated seats
Old Apr 17, 2008 | 09:57 PM
acofficer's Avatar
Default Quattro heated seats
I have a pair of Quattro Heated seats that I am installing in a 1972 Jeep Commando. I need help from the experts on how I can wire it. It has the six pin green connector. I know the pin order is the following:
Left Center Right
upper]looped looped thermostat
female female
lower] Groundthermostat power
Is there any way to wire it without relays or thermostats?? I obviously know what to do with the ground and power, but what should I do with the other pins? I would love to just be able to hook it up to a toggle switch for just on and off. But PLEASE let me know your thoughts. Thanks in advance. --Jamie
Old Apr 18, 2008 | 03:53 PM
tHe kNiGHt FaLL's Avatar
Default RE: Quattro heated seats
is it the entire seat...?
and is there a control module underneath the seat...?
w/o a thermostat to regulate temperature the seats will get too hot to sit in and burn up the heater elements.
it is possible... but you need to be extremely good w/ wiring / electrical.
Old Apr 18, 2008 | 04:52 PM
acofficer's Avatar
I have the entire seat but I didn't see any kind of control module on either one. Just the green plug connector. I would assume the thermostat works by reducing voltage to the pads. If I put an inline resistor what voltage should I bring it down to? Even if I can do that I am not sure on which pins to wire to each other. Any suggestions? --Jamie
Mhuntington
Feb 4, 2014 02:28 PM
vtraudt
Oct 8, 2012 05:39 PM
SouRce4
Dec 13, 2006 01:02 AM
bmdub5
Aug 31, 2006 04:24 PM
