AM/FM Radio Reception
I am having trouble with my AM/FM radio reception I have an '02 A4 1.8T and I have the Bose system in it. I love the system but the radio doesn' t work at all. I went to the dealer and they said I would need a booster which will cost $300. I was wondering if anyone has had the same problem and if there is any way to fix this problem without spending that kind of money.
Yes its a fairly regular probem and the only way to fix it is to replace the booster. You may be able to do it yourself. I dont recall exactly but i think it may be under a trim panel at the top of the rear window on your particular model. If thats the case carefully pry out the panel. Its about 2-3 inches wide and spans the lenth of the rear window. Under that is the diversity antenna. Unbolt/clip it and put the new one in.
