Annoying Misfire!!
Old Aug 17, 2014 | 08:20 AM
josh A8's Avatar
Old Aug 17, 2014 | 01:03 PM
Brityank's Avatar
I pulled the o2 sensor from the drivers side header and started the motor with no change, so that ruled out a blocked cat.
The ignition module is fine and I found the problem............big *** air leak! The gasket for the EGR didn't seat correctly. I went round the motor with a can of carb cleaner and stalled it out when I hit the EGR.
I checked all connections, fittings and hoses etc one more time, cleared the fault codes, then fired it up.
It settled into a nice idle in less than 10 seconds. I ran it up to running temp (radiator fans kicking in) and there were no leaks, knocks etc. I even got the tranny warm enough that I could correctly level off the fluid. (I changed the filter and fluid out a while ago, just never been able to run the thing up to temp to level it correctly)
I stopped and started it a few times but still no codes, so fingers crossed all is well in my little Audi world :-)
I'll know for sure when I can drive it. I still have a few smaller jobs to do before that happens though, but compared to getting it running correctly, they're minor!
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
A4_1.8_20v
Jan 22, 2006 11:59 AM
