Audi A6 2.7T Secondary Air Valve woes...
Old Jul 14, 2004 | 10:34 PM
uber2k's Avatar
Default Audi A6 2.7T Secondary Air Valve woes...
Hello,
I have been experiencing a rattling noise coming from the engine-bay during startup.
My local audi dealership took a look at my car this morning and told me that the noise was a combination of a small exhaust leak and the secondary air valve.
The exhaust leak has been fixed but my mechanic tells me that there is nothing that there can be done to fix the sound coming from the S.A.V. as it is a common problem with other 2.7T models.
Does anyone else have experience with this problem?
If so were you able to find a fix?
Any feedback would be greatly appreciated.
Old Jul 14, 2004 | 10:59 PM
ImolaS4's Avatar
Default RE: Audi A6 2.7T Secondary Air Valve woes...
That sounds like some sort of hooey!
If the valve is bad, then it needs to be replaced (along with a new vac hose probably). It will cost around $125 for the parts.
Old Jul 14, 2004 | 11:06 PM
ImolaS4's Avatar
There is also gasket that is known to leak. The resultant sound is like a diesel.
I'm surprised the mechanic didn't speak of an incorrect flow DTC.
The gasket should be sold with the valve. Replace the gasket, and it should sound normal again.
Old Jul 14, 2004 | 11:16 PM
ImolaS4's Avatar
Just an fyi:
During cold starts, the valve on the back of the head starts to pulse while the secondary air pump moves fresh air into the head under pressure. This air flows over the back of the exhaust valves causing a vacuum inside the exhaust side of the head.
mhoward
B7 Models
Jun 26, 2013 04:49 PM
retho78
Jan 15, 2013 05:59 PM
mmart007
Aug 27, 2011 01:01 PM
wtlee3
Dec 27, 2010 11:09 AM
07titanium
B7 Models
Mar 5, 2009 08:29 PM
