Audi B5 coding issues
Old Oct 30, 2013 | 12:33 PM
Jonh F.'s Avatar
Default Audi B5 coding issues
Hi everyone,
I have problems coding the ECU from auto to manual trasmission with VCDS.
I have a CEL due to improper coding, and when I try to code in ( for me its :06001) the correct values it doesn't save, it stays on the auto values :06051.
Here is the list from VCDS for check engine codes.
Wednesday,30,October,2013,10:18:40:31777
VCDS Version: Release 12.12.0 (x64)
Address 01: Engine Labels: 058-907-55x-AEBN.lbl
Control Module Part Number: 8D0 907 557 N
Component and/or Version: 1.8l R4/5VT MOTR AT D03
Software Coding:06051
Work Shop Code: WSC 00000
VCID: 3B7B3D6E291981C6811-4B18
3 Faults Found:
18021 - MIL Control Circuit
P1613 - 35-00 - Open or Short to Plus
17746 - Camshaft Position Sensor (G40)
P1338 - 35-00 - Open or Short to Plus
17884 - EVAP Leak Detection Pump
P1476 - 35-00 - Malfunction / Insufficient Vacuum
Readiness: 0010 0101
I know you can recode these from auto to stick or the other way around, they have pre-program software for all the types of drivetrain, it just doesn't save the changes, I maybe need a login code , i tried logging in with 01283 already, Mr. Uwe from Rosstech is helping right now.
Only thing left to get out of limp mode is the recoding, please if you have any idea, let me know! Thanks.
Old Oct 30, 2013 | 06:17 PM
Jonh F.'s Avatar
I dont want to bump or anything like that but I really need to know what's going on, more info about the car will help maybe..
Its a 1997 A4 B5, 1.8T FWD, it had the 8D0 907 557 N ECU that I chipped stage 1 and it developed a missfire on cyl. 3 , cause was the ECU giving constant ground going in the ICM on pin 3.
I bought another ECU with the same numbers, only thing is its from a 1996 car, can the production date have any impact on software that was integrated in the ECU??, I know they were not introduced in North America before that or something like that, i saw this on the forum so I am not sure if its true.
Mr. Uwe said some AEB's ECU's had a bug of some sort wich made them programable in one way but not the other, if at least somebody ever recoded an ECU on a AEB platform, can that person give me the ECU number's ? that way I could go ahead and buy another one that will work, if its really the cause.
For now its in limp mode, 5 psi running like crap, I will get a new camshaft sensor in this week, I dont know why it fried but it did.
Anyway thanks for any help, its really appreciated and my wife could get her car back before winter hits, so I can get my Benz back XD!
Old Nov 10, 2013 | 01:29 PM
Jonh F.'s Avatar
Update on the car, New cam sensor still getting code,
BUT I tried coding the old ECM and it worked flawless back and forth, my old ECM number on the case is 8D0 907 557 N but in VAG com it says 8D0 907 558 M! How is that possible?? anyway buying another ECM this week with these numbers cause I know it works, still have the stupid CPS issue, why does it give me that code when every damned thing is spot on!!!? It never gave that code before and after the rebuilt, just after the new ECM was in.
And I see not alot of people are active on here but still, the main purpose of me posting this is to get help but also to help for future questions from clueless people like I was 4 months ago.
Have a good day people.
Old Nov 10, 2013 | 04:36 PM
M5S5's Avatar
Tech Certified
I think you will need a super vag or a 5052/5054 to get the secret code for unlocking the ecm.
Old Nov 19, 2018 | 02:24 PM
mrs.missme541's Avatar
Hi anyone in butte county california thats knowledgable with this coding and possible immobilizer access login to fix my 99 audi a4 quattro 1.8t with a awm motor it started with an oil pan and to dead battery for a few days. and since then ive replaced throttle body, camshaft sensor, crankshaft sensor, MAF, ignition control module, tested turbo, lost keys and had to replace ignition and now dont have a door lock key and im just so frustrated my husband left me and im still one state and 8 hours from home. im outside oroville and low on funds but i did buy an obdeleven to help trouble shoot but i need all sorts of logins to do any coding I want to go home ugh please help if possible.
calhoun_d
Apr 20, 2014 09:27 PM
dtopland
Aug 27, 2013 10:31 AM
nemohm
Sep 5, 2008 05:54 PM
turbo kraut
Mar 27, 2008 08:40 AM
Aliel
Mar 10, 2005 04:38 AM
