18010 - Power Supply Terminal 30: Voltage too Low
Old Mar 7, 2005 | 07:21 PM
Aliel's Avatar
Default 18010 - Power Supply Terminal 30: Voltage too Low
Guys I keep clearing this code and it keeps coming up... Anybody knows what it might be?
Address 01: Engine
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
P1602 - 35-00 - -
Readiness: 0110 0101
Old Mar 7, 2005 | 08:14 PM
TomRitt's Avatar
Default RE: 18010 - Power Supply Terminal 30: Voltage too Low
I got this code too not sure what it is though
Old Mar 7, 2005 | 08:19 PM
TomRitt's Avatar
Did some research, it usually a result of pulling the ecu, or disconnecting the battery and should go away shortly, if not it could be a short b/w o2 sensor wires
Old Mar 9, 2005 | 03:56 PM
Aliel's Avatar
Ok I asked my mechanic and he says that code is not a problem at all. It shows in all the chipped cars because when you turn off your car the chip resets the ECU and the car thinks the ECU was removed and put back. So we are going to have this code no matter what.
Old Mar 9, 2005 | 05:23 PM
Jestnomen's Avatar
6th Gear
wth, that is a load of bull! If your ecu was reset every time, then you would have horrible idling each time you turned on your car.
Old Mar 10, 2005 | 01:08 AM
david9999's Avatar
My car is chipped and I have no codes
Old Mar 10, 2005 | 04:38 AM
TomRitt's Avatar
Yea it doesnt reset the ecu everytime otherwise fuel trims would be reset and as was stated above the car would idle like crap. Its simply turns on when the ecu loses power (you took out the ecu, or disconnected the battery), it should turn off
bigdyll
Feb 29, 2012 10:10 PM
sukisuru
Feb 11, 2011 01:53 PM
KinkySlayer
Oct 19, 2010 07:20 PM
KfabR8
Aug 21, 2008 09:11 PM
jchaffee1
Apr 10, 2008 09:39 AM
