Audi dashlights
Old Mar 31, 2006 | 12:39 AM
rex2285's Avatar
Default Audi dashlights
Hey guys, ok I have a 1987 4000S, I use to have my after market stereo hooked up and working fine, until I recently stripped the interior. It's all back together now but my problem is that I forget were I had my assecory power, from my deck hooked up too. Does anyone know where I can tap into some power, so when I turn on my ignition, my deck will turn on? I forget the color codes for an audi so I dont want to tap into the wrong wire. Any suggestions? thnx in advance.
Old Mar 31, 2006 | 12:41 AM
rex2285's Avatar
Default RE: Audi dashlights
oops sorry, wrong header. changed my question.
Old Apr 3, 2006 | 10:44 AM
kraylon's Avatar
does the cig light work when to key is off is so tap into the wire that goes in the middle or if not you can always go to the ignition wires if you have a muti-meter it is pretty easy to find it will only show power when the key switch is run and accersory the cig lighter is the easyest to test but it may be wired to constat power
