B5 S4-P0301-New Maf, plugs, filter. Not coils..WHAT?!?!
Old Oct 31, 2011 | 06:08 PM
blu.suede's Avatar
Default B5 S4-P0301-New Maf, plugs, filter. Not coils..WHAT?!?!
About two weeks ago my car started running very very rough, the motor would feel like its jerking back n forth and the exhaust sound is very gargled. When I checked the CEL I got a random misfire code, and small air volume code.
So Ive changed the spark plugs. (gaped them correctly)
Ive bought a new mass air flow sensor and intake filter
Started her up let her run for a min. then i took it for a spin.
Same effect as before. I didnt have a CEL but i connected the scanner and it doent give the same codes as before. This time no "air volume" code or whatever.
And it changed from "random cylinder'' to "Cylinder 1" misfire.
I took the coil pack from cyl 2 and switched with cyl 1 to see if its the coil pack.
No luck.
Could it be the ICM? how would I test if it good or not?
or could it be a massive air leak? (I have true dual all the way back so i cant listen for any air hissing)
Need help guys!!
skidmarkart
B7 Models
Apr 10, 2015 01:46 PM
rdlmitedu
B7 Models
Mar 17, 2014 04:50 AM
robertclark0
Apr 27, 2011 01:33 AM
browny355
Jan 20, 2011 11:59 AM
Dan1969
Sep 7, 2009 10:01 AM
