Blowers: faulty or just rubbish?
Old Nov 23, 2006 | 06:47 AM
burt_girth's Avatar
Default Blowers: faulty or just rubbish?
'ello - got a minor problem and I thought I'd mention it to you lot as you very kindly fixed another problem of mine a while back -
The blowers: Don't seem to be working. I've only noticed this now it's gotten cold in the mornings - no matter what setting the (digital) display is (compressor on, demist, top, bottom, middle vents) nothing much seems to happen - you can feel the warm air, but it's not being blown; the faster you go, the more air you get through. I'm going to check the fuse (in port 25, from memory) but if that's ok, I don't really know what to try next, so any suggestions would be welcome!
A4 TDi SE, 1998, 150k
Best car I've ever had, btw
Old Nov 26, 2006 | 08:47 AM
dankhound's Avatar
Default RE: Blowers: faulty or just rubbish?
Check power and ground at the motor. Youll have to remove the glovebox to do that. If you have 12v and a good ground replace the motor.
Old Nov 29, 2006 | 07:02 PM
burt_girth's Avatar
Thanks, I'll give that a blast; I'll let y'know if that works. Ta!
tyron2000
Feb 1, 2013 02:29 PM
turborado
Nov 28, 2011 08:20 AM
Quattro Power
B7 Models
Dec 18, 2010 10:34 AM
mikeko
Aug 3, 2007 10:46 AM
powman
Apr 24, 2007 02:35 PM
