Blown Blower motor fuse
Old 10-29-2007, 11:04 PM
yknits18's Avatar
Default Blown Blower motor fuse
I keep blowing blower motor fuses. I have dropped the dash and traced the wire and there are no worn wires. I was told it was the blower motor resistor. I called the dealership and they told me that my car doesn't have one. I tried changing the blower motor. It still blows fuses. The weird thing is it will not blow the fuse until I start the car. If I leave it in accessory, it doesn't pop the fuse. Any help would be appreciated. I am at my witts end.
Old 10-30-2007, 12:21 AM
yknits18's Avatar
Default RE: Blown Blower motor fuse
I have more info if this helps. If I put it on econo the fuse doesn't blow. If I switch it of econo the fuse blows.
Old 11-03-2007, 12:57 PM
dankhound's Avatar
Any faults in the ac control head? You have a short to ground somewhere. Youll need a wiring diagram of that circuit. Then you can start disconnecting things on the circuit untill you are able to start the car without blowing the fuse. That should help you trace the wire that is shorted.
Old 11-03-2007, 01:14 PM
yknits18's Avatar
What is a ac control head? Is it the piece with the selector buttons for the ac?
Old 11-03-2007, 02:42 PM
dankhound's Avatar
Yep thats the one. Theres a control module inside that can store faults too.
Old 06-07-2008, 10:49 AM
yknits18's Avatar
I finally fixed it. It was my A/c compressor that was seized. I changed the compressor, the accumulator, and te orifice tube. My mechanic told me that the A/C had died because I had charged it with freon that had leak sealer in it. I wont do that again. I appreciate all the help I recieved. Thanks again.
Cribbs767
03-18-2015 04:29 AM
mtnxtreme
Audi Q7
12-28-2014 10:01 AM
fpdlskf
06-27-2011 04:04 PM
wvning
12-05-2008 10:06 PM
Quick Reply: Blown Blower motor fuse
