Boiling Radiator Coolant
Old May 20, 2010 | 05:24 AM
imrankz's Avatar
Default Boiling Radiator Coolant
hi guys, i'm new here. ive been having this problem for the past few weeks where i have to add water to the radiator reservoir everyday after any driving the day before. i am wondering whether the problem might be the gasket? any quick fix for this?
Old May 20, 2010 | 09:12 AM
02A6Beau's Avatar
you need to find out where the coolant is going before you can fix it. Could be as simple as a cracked hose, cracked coolant tank or leak around a sensor, to a leaky thermostat, water pump...
if you can't see anything "wet" from the top, remove your belly pan and put a big piece of cardboard under the front of your car when parked, then look for the drips to get an idea of where the leak is (front, rear, left, right, center
Old May 23, 2010 | 12:53 PM
imrankz's Avatar
when the engine was running, the water + coolant boil up and come out through the cap.
Old May 26, 2010 | 10:33 AM
boostedcircles's Avatar
Sounds like you need a new cap.
SubaruHyundaiAudi
Nov 20, 2013 10:31 PM
Stevenw83
Jul 16, 2010 01:20 AM
imrankz
May 20, 2010 04:57 AM
xitsmike
Oct 3, 2008 12:24 PM
shady927
Apr 11, 2008 06:46 AM
