radiator coolant
Old Apr 10, 2008 | 03:20 PM
shady927's Avatar
Default radiator coolant
My radiator coolant level is low, can I just fill it will regular coolant or do I need a special kind opf coolant?
Old Apr 10, 2008 | 04:54 PM
cincyTT's Avatar
I'm make believe
Default RE: radiator coolant
check the filler cap, you will need to use g11 or g12 to top it off. Other stuff will gel the old coolant. You can also just top it off with some distilled water since its getting warm out.
Old Apr 10, 2008 | 11:52 PM
shady927's Avatar
I went to audi today to get some coolant and before I put it in I noticed the coolant in there is blue, the stuff they gave me is red....Can I still use it or should I take it back?
Old Apr 11, 2008 | 02:31 AM
shady927's Avatar
is it okay to fix coolants????
Old Apr 11, 2008 | 06:46 AM
99A4NOW's Avatar
Do as cincyTT said and add distilled water for now- save your "red" coolant. If the level is low that may mean you have a leak. Find that first, fix it, then have the system flushed and add the correct G12 coolant.
MirzaRamovicPNW
Sep 3, 2012 12:55 AM
sivak.puvvula
Dec 27, 2010 11:22 AM
imrankz
May 26, 2010 10:33 AM
imrankz
May 20, 2010 04:57 AM
southcoast
Jan 22, 2007 11:12 PM
