Boost Leak?
Old Apr 7, 2008 | 07:19 PM
CineDiablo's Avatar
Default Boost Leak?
Hi everyone,
I'm a newbie to the forum and would appreciate any advice from the more experienced car afficianados on the board.
I just ran a vag test of my 2003 Audi A4 1.8T and receivedthe followingmessage:
Address 01: Engine
Controller: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0001
Coding: 0016581
Shop #: WSC 63351
1 Fault Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded
Readiness: 0000 0000
Is this a boost leak?
Thanks for the advice!
Old Apr 9, 2008 | 07:06 PM
tHe kNiGHt FaLL's Avatar
Default RE: Boost Leak?
could be... but usually there is a fuel mixture fault as well and the engine will normally stumble.
i'd remove the bypass / diverter valve and check the rubber diaphram for holes
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
