BOV's, DV's and the Audi closed loop turbo system.
Old Feb 17, 2010 | 10:48 AM
  #21
bboy1O1's Avatar
Default yep
There should be a dail on the bottom of the dv/bov, rachet action, basically its the whole top of the dv. When you turn it you should see the dv start to open up (you will only see this when its active so you have to stick your finger up the bottom and push it up). I usually have mine at about 30 dv 70 bov in normal driving. hope this helps
Old Feb 17, 2010 | 04:31 PM
  #22
aesmith0506's Avatar
Default Well.....
I apprectiate your suggestion, but i just tried this after your reply... Turned it all the way one way... got nothing... tried it all the way the other way...still nothing tried everywhere in between but still didnt get anything... so then i thought maybe i out the valve on backwards.. so i switched it around tried turning the dial every which way and still didnt get anything... I'm begining to wonder if my cars even building up boost.... I just got my audi a week ago and it doesnt seem like it is much faster than my wifes eclipse.. Could my cars turbo have just went out?
Old Feb 18, 2010 | 05:58 PM
  #23
bboy1O1's Avatar
did you stick something up the bottom to make sure the sping isnt bad/locked up. I mean if your turbo went out you'd be able to just feel that, if its a 5 spd or not when it switches gears you can feel the turbo yeah?
Old Feb 19, 2010 | 12:24 AM
  #24
Ya I Stuck My Finger Inside It And It Pushes Up Just Fine..... I Believe My Turbo Is Def. Not Working... I Do Not Feel It When I Am Shifting
Old Feb 22, 2010 | 10:56 AM
  #25
bboy1O1's Avatar
Well that would do it, no pressure no blow-off. Might as well go for the t3/t4 upgrade now.
Old Mar 18, 2010 | 07:39 PM
  #26
fliparto's Avatar
Can someone post pics of the s4 DV installation? There are some clamps in there Im wondering how they hell they closed them. Also I want to confirm the direction Im installiing them, though I think its obvious. Plus any comments / suggestions are appreciated too. thanks
Old Mar 30, 2010 | 06:57 AM
  #27
joenelson7687's Avatar
what kind of dv are you installing? the clamps are the non-reusable ones...so just get them off and replace them.
Old Jun 4, 2010 | 06:14 AM
  #28
dodu's Avatar
Thanks finest cars and new cars latest models http://shortlinks.co.uk/1pil 2010
Old Jul 1, 2010 | 07:36 AM
  #29
mkhussey94's Avatar
Go to they are really good with tuning there
Old Jul 22, 2010 | 03:27 AM
  #30
jucky68's Avatar
do any chips enable the ability to install blow of valves?
