BOV's, DV's and the Audi closed loop turbo system.
Old Oct 26, 2010 | 03:37 PM
  #31
mrwickedd's Avatar
what would you guys recommend for a 2007 A4?
Old Oct 27, 2010 | 01:34 AM
  #32
tuned2.7A6's Avatar
Originally Posted by Courtsmith
So, would using the Forge "splitter", DV in combination with BOV, be a bad choice for my 2001 audi TT Quattro 225HP? Or should I just stay with the DV?
I have a 2.7T engine (twin turbo) and have installed the Forge spliter DV which is semi atmospheric semi recirculating and work fantastically. I talked to Forge directly and asked if it would be okay to run this DV apposed to the standard 007, and they told me that it does the exact same job... If you go full atmospheric, I was told, it will probably bring up a check engine light. The only downside to these DVs is if you are a symmetry freak - they install asymmetric on the 2.7t engine, e.g. one "horn" for the atmospheric discharge faces one way and on the other DV it faces the other way... hope this info helps!
Old Jan 15, 2011 | 01:59 PM
  #33
Nero333's Avatar
Default Yo, yo...
Thats a Sick setup...
Old Jan 25, 2011 | 11:09 PM
  #34
treyg's Avatar
Does anyone have experience with the Hybrid BOV/DV's on ebay?
http://cgi.ebay.com/ebaymotors/VW-AU...#ht_1384wt_831
Old Jan 26, 2011 | 07:40 PM
  #35
bboy1O1's Avatar
Default Yeah
I have that exact one installed in mine, it works perfectly. Cheapest I've found so far.
Old Jan 27, 2011 | 01:13 AM
  #36
treyg's Avatar
Awesome. What about the sound?
Old Jan 30, 2011 | 07:34 AM
  #37
greddyrcng's Avatar
Default 2.7 t
will the ones on ebay for the 1.8 work for the 2.7 ?
Old Feb 13, 2011 | 12:10 PM
  #38
dainstaller's Avatar
Default turbo issues
i just got a 1997 a4 quattro and the last owner took things out which didnt need to be taken out so , iam in need of a full diagram for the turbo and all its hoses so i can put it back to factory and maybe get my turbo working again also my cluster panel doesnt work and i need some help on this issue plus my mas air flow sensor has been cut so i need to know which wires go to which pins so i can connect them back ill be grateful if anyone could help me out here ill leave my phone so just incase anyone can help iam in south jersey NJ my number is 1-908-209-4882 ,,,,,plz anyone help me out i need this car ready for some mayor car shows for this summer , thk u
Old Dec 25, 2011 | 10:58 AM
  #39
eza-ali's Avatar
Default Audi
Lighter. Faster. More efficient. It’s the best version yet of a best-in-class vehicle. A lighter steel-aluminum construction increases performance, efficiency and safety while options like Audi quattro® all-wheel drive and Audi drive select make it capable on any road. The 2012 A6 exemplifies the progressive executive sedan.
Old Jan 31, 2012 | 07:28 PM
  #40
AntarS4's Avatar
hi im looking to make my b5 s4 blow off and one can give me some help???
