BRAKE ISSUE
Old Jun 25, 2008 | 05:05 PM
MAXALFA's Avatar
Default BRAKE ISSUE
HI I HAVE A 99 AUDI A-4Q THE PROBLEM IM HAVING IS WHEN I TURN TO THE RIGHTONLY AND STEP ON THE BRAKE PEDAL IT FEELS LIKE SOMETHING IS MOVING UP AND DOWN AND SOMETIMES IT DOES THIS GOING STRAIGHT AND STOPPING AT A SIGNALLIGHT AND BRAKE. WHAT SHOULD I LOOK FOR? THANKS MAX
Old Jun 26, 2008 | 12:07 AM
WolfsA62.8Q's Avatar
Default RE: BRAKE ISSUE
Max, first turn your Caps Key off... all capital letters looks like shouting, and you might not get many responses.
Pull the wheels off, check the brakes, you may have something loose... brake pads/ calipers.
Old Jun 27, 2008 | 01:02 AM
matasci's Avatar
do you get an abs light when this happens? if your car has a vacuum brake boost it might be going bad or have a lose connection
Old Jun 27, 2008 | 03:20 PM
MAXALFA's Avatar
HI I dontget aabs light on when this happens but i will take a look at the brake boost is thereanything else i should look for?THANKS
Old Jun 27, 2008 | 11:24 PM
ImTheDevil's Avatar
Biggest thing is what Wolf was saying - take off the wheels and check everything carefully - make sure all the required bolts are there and are torqued correctly, and make sure the pads are seated correctly. Also, when you reassemble, be absolutely sure you use a torque wrench to set your lug torque to 90 ft-lbs, and torque in the "skip-one" star pattern.
abc27
Aug 25, 2013 04:19 PM
Larrysa4
May 28, 2012 10:54 PM
Andrew149
Sep 15, 2009 03:22 PM
Dallas09
Feb 14, 2009 05:08 PM
k5gixxer
Dec 17, 2006 11:53 AM
