Can anyone tell me what this is...
Old May 5, 2008 | 09:58 PM
Prerunnered 1.8t A4's Avatar
Default Can anyone tell me what this is...
So I was running a check engine light so I put the scanner on it...
I got this code. p0688
ECM/PCM power relay sensor circuit
What is this part and where is it located.
I have a 2003 a4 1.8t
TIA!!
Old May 6, 2008 | 09:09 AM
CRAZYHAWK's Avatar
Default RE: Can anyone tell me what this is...
17072 - ECM Power Relay Load Circuit: (J271): Open Circuit
P0688 - 35-10 - - - Intermittent
Check thevoltage to the ECU.
Old May 6, 2008 | 02:18 PM
How do I do that?
Wheres the relay box located... Im not too good with Audis but I know on every other car theyre usually under the hood somewhere in a lil black box
Old May 8, 2008 | 11:23 AM
CRAZYHAWK's Avatar
Look to the driver's side of the battery.
Old May 9, 2008 | 10:54 PM
I changed out this relay that everyone told me it was and its still not starting... There was no relay with 271... there was a 219. thats the one I changed. 40 bucks!
CPS now?
I dont wanna keep dumping money into it and it not be needed.
Old Jun 21, 2012 | 09:03 AM
DennisO's Avatar
Got the same problem. My 2003 A4 w/1.8T will turn over but won't crank. Pulled a code P0688 and it also blows fuse #29 that the owners manual says is "engine timing". The pics helped a lot. Any ideas what is broke?
DennisO
