can I drive with a bad coil??
Old Mar 7, 2008 | 06:33 PM
danceingbuck's Avatar
Default can I drive with a bad coil??
I took the car to get scaned.. It turned out to be a bad coil in #2..It runs ruff at low RPMs.. should I park it til I get my parts or can I drive it to work, it's just 3 miles each way....
Old Mar 8, 2008 | 11:00 AM
Yentemad's Avatar
Default RE: can I drive with a bad coil??
you might waste a little more gas than usual, and have a slight hesitation. but i see no catastrophic problems
Old Mar 8, 2008 | 11:09 AM
techbod's Avatar
engine warning light on CEL? if yes the get the fault codes
Old Mar 8, 2008 | 11:13 AM
techbod's Avatar
my appols the answer is no
Old Mar 9, 2008 | 05:37 PM
tHe kNiGHt FaLL's Avatar
bad coil means flashing CEL.... flashing CEL indicates a federal standard of a"catalyst damaging misfire"
CAT... DAMAGING...
is your motor going to blow...? No. but emission equipment are not cheap either.
Old Mar 9, 2008 | 10:54 PM
Audi Hun's Avatar
Do not drive.
And also the "misfire error" goes record in the computer. After you fixed the problem may you need delete this.
I have coils if you need.
Joseph
Old Mar 12, 2008 | 08:08 PM
Thank you !!!!!! I won't drive
Old Mar 12, 2008 | 10:57 PM
boostfeen's Avatar
So if your check engine light is flashing then it has to be a catalyst damaging misfire? It doesnt flash for any other reasons because mine is flashing and I have a real bad vibration through the drivetrain when pulling up through all gears! And at idle just sitting in neutral the engine is running good with smooth rpm's right where there supposed to be but the engine is shaking a little, and it gets worse when you rev it, I think it might be a dual mass flywheel gone bad as it has 95K on it. Its the car in my signature! Thanks guys
Nov 20, 2010 03:40 PM
kbevere
Oct 14, 2010 09:36 AM
drft1
Jul 5, 2010 12:19 PM
kraylon
Jul 29, 2009 12:19 AM
danceingbuck
Mar 7, 2008 06:27 PM
