car jumps forward as I try to move forward
Old Jul 24, 2015 | 03:23 PM
sainy's Avatar
Default car jumps forward as I try to move forward
Hi Guys
My audi A4 automatic (2002).
When in D and I try to move forward and I lift my foot off the brake, car jumps. Sometimes it stalls other times it will jerk couple of times before moving of.
I was told it is transmission oil and filter. I spent £85 getting that done. Problem still persists.
Any clues guys, what could be?
Thanks
Sainy
Old Jul 25, 2015 | 09:31 AM
dave944's Avatar
Are you getting any OBD codes about the transmission?
Old Jul 26, 2015 | 01:12 PM
sainy's Avatar
Hi Dave
I dont know what you mean by "OBD codes". But there is nothing coming up on the dashboard, that would give any hints that something is wrong.
Dashboard looks normal as ever.
Hope you can guide me.
Thanks again
Sainy
Old Jul 26, 2015 | 09:51 PM
dave944's Avatar
You need to have the OBD (On Board Diagnostic) codes read from the car. An automotive parts store should be able to connect a regular code reader to the car to see if there are any codes in memory that might indicate an issue. There are actually two computers on board the car. One for the engine and one for the transmission (automatics). The reader should be able to communicate with both.
However, what you are describing sounds like a mechanical issue inside the clutch packs in the transmission. There are spring plates in the clutch packs that help smooth the physical engagement of the clutches to make the car move in each gear.
See if you can get any OBD codes first though.
Old Aug 4, 2015 | 01:23 PM
sainy's Avatar
Hi Dave
Many thanks buddy, I am going to get that done asap.
Regards
Sainy
amirjhb
Dec 9, 2014 04:09 AM
calmone
Dec 31, 2010 07:23 PM
Teutonic2.7T
Mar 3, 2008 11:56 AM
hiwords
Jul 8, 2007 02:41 AM
XCLR8TT
Jan 12, 2007 05:18 AM
