car is smoking from exhaust
From my response to the OTHER thread you made, with the SAME question:
first, are you sure it's smoke, not steam. It being winter-time, when you first start up the hot exhaust gasses condense into steam, by the time they make it all teh way to the end of your cold, cold exhaust-pipe. At least until the exhaust heats up, then the steam-ee-ness goes away.
now, if THAT'S not what you're dealing with...
smoke out the tail-pipe generally falls into one of two categories. Either piston rings, whch can be moderately expensive to repair, but, it only gets worse, and potentially more expensive to repair as time goes on. Or, head-gasket, which can also be moderately expensive to repair, but, if the head-gasket BLOWS (which, it eventually will, sooner later, if it's what the problem is), and, if it does go you MAY need to replace the engine, itself, depending on how much collateral damage is done.
go see a mechanic and have them check for oil in your coolant, or coolant in youroil, if yes to either, there is the very real possibility that you have a cracked head-gasket. If not, get a leak-down test, to find out which cylinders' rings are worn, then, replace all of them, just to be safe!
Now, *I'M* not a mechanic, my advice is based solely on my personal experiences. For qualified advice, I'd recommend sending a PM to rayveedub, or avant80@2.6, or dankhound, or rbtech. They are actual mechanics who hang around the AF, and tend to give better guesses than anything *I* could ever "know."
