check engine that cant figure out
Old Jan 1, 2013 | 11:49 AM
rmr1499's Avatar
Default check engine that cant figure out
ok s posted this in the b5 area awhile ago and nobody could help. got a 96 audi a4 it is quattro and a 5 speed has v6 2.8l 12v sohc afc engine code. 235k on it. ok so this all started after i had my flexpipe replaced. right after that i got check engine codes. all 4 o2 sensor heat ciruict code EGR valvle electrical malfunction and fuel evap ventilation valve electrical malfunction. i replace the egr valve and the egr valve seloniod. also pulled the intake off cleaned it all out new gaskets all that good stuff. and right before the exhause was done i put brandnew rear o2 sensors. well still cant figure it out pulled the ecu cleaned all contacts. took the grounds and cleaned them off the ones under the coolant box and the one on throtttle body and then the ground on passenger side motor mount. so anyone have any ideas
Old Jan 1, 2013 | 11:58 AM
02A6Beau's Avatar
what codes, exactly, are you getting? Try clearing all your codes, drive for a bit, see what comes back. sometimes specific codes have a specific solution. it is more effective than just saying "I have an evap code" then taking the shotgun approach to trying to solve the problem
good luck
Old Jan 1, 2013 | 12:22 PM
rmr1499's Avatar
i told you exactly what codes they are minus the numbers cause my scanners at my dads house right now and i did that i keep doing that they come right back on there all electrical malfuncuction codes
Old Jan 1, 2013 | 01:04 PM
rmr1499's Avatar
P1409 tank ventilation valve circ. electrical malfunction
P1400 egr valve circ electrical malfunction
P0161 o2 sensor heater circuit bank 2 sens2
P0141 o2 sensor heater circuit bank 1 sens 2
P0155 o2 sensor heater circuit bank 2 sensor 1
P0135 o2 sensor heater circuit bank 1 sensor 1
Old Jan 1, 2013 | 07:02 PM
rmr1499's Avatar
bumppp
Old Jan 2, 2013 | 10:13 AM
rmr1499's Avatar
anybody?
Old Jan 2, 2013 | 09:21 PM
rmr1499's Avatar
really nobody out there has anything
Old Jan 5, 2013 | 10:09 AM
rmr1499's Avatar
bump emission test soon
joeynach
Aug 27, 2011 06:57 PM
A4TOTT
Mar 5, 2010 11:48 AM
Vegas34
Apr 20, 2008 01:35 PM
a4autocrossr
May 9, 2006 08:05 PM
