Check Engine Light?
Old Jan 26, 2008 | 09:21 AM
KiserRN1981's Avatar
Default Check Engine Light?
I own a 2001 A6 2.7T, and I have been expiriencing intermittent rough idles. Temperature does seem to play some role (worse when cold), but it is inconsitent. I also have had a 2MPG drop in fuel efficiency the last 2-4 mos. So my question is could it be an O2 sensor, and idle sensor, or some other sensor without triping the check engine light??? Techs please help. Thanks.
Old Jan 26, 2008 | 05:21 PM
WolfsA62.8Q's Avatar
Default RE: Check Engine Light?
Check your coolant temp sensor, I think it's in the rad.. known to cause a drop in mileage, as the ECU gives the engine more fuel thinking it's not warmed up yet.
Old Jan 26, 2008 | 09:13 PM
SAudi's Avatar
if you got a CEL pull the codes and then report back to us for a more thorough look into solutions. pepboys should still pull thekm for free.
Old Jan 27, 2008 | 12:46 PM
Pep boys should be able to give you the codes, now if you're going to keep the car for a while, get a VAG-com, great for diagnozing faults and/or modding our Audis, and finding faulty O2 sensors.
VAG-COM is your friend.
Old Jan 28, 2008 | 03:23 PM
brycip's Avatar
can someone help me i am getting a check engine light and i have an after market radio audi says i need original inorder to get the codes does and one know the relay to bypass this?
Old Jan 28, 2008 | 08:59 PM
jgurland's Avatar
I'm no expert, but I think it could have something to do with the air injection system. From what I understand, there's a pump that sucks air into the system to control how rich the mixture of air and gas is, particularly at various temperatures. If you have a cracked hose (or pipe - I think they may be plastic pipes) you'll get an air leak and the system will become inefficient.
As a result, you'll get a rough idle because it will have trouble controlling the richness of the air/gas mixture.
Hopefully someone who knows better than I do will come along and correct me if I'm wrong.
Old Jan 28, 2008 | 11:06 PM
dankhound's Avatar
You dont need the original radio, but you will need to pull your radio and do some rewiring. Whoever installed the radio either shorted or powered the data bus wire on the radio causing the whole system to go down making the scan tool not comunicate. Sometimes just pulling the radio fuse will work, but sometimes a rewire of the radio is needed.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
