Check Engine light...real bad?
I have an '04 CPO Allroad, and the 'check engine' light has been on for a few days. I haven't had the time to get down to the dealership.
I tightened the gas cap...are there any other obvious, fixable problems that lead to this light being on? Would a VAG tool tell me what's wrong? Should I drive the car into the river and get the insurance money?
Thanks in advance for any help/advice.
john
john
go to autozone or advance and get them to read the codes for free.. but dont buy anything off of them yet. if your code is some sort of evap leak then have them clear it and make sure your gas cap is always on tight. if its another code then quick reply them and we can go from there. and if your engine light is on and flashing do not drive the car as it is a misfire condition that will damage your catalyst...
take it down to the dealership right now. your CPO will be voided if you continue to use your car despite the light on. either that or dont drive it at all and get it ASAP. Time is of the essence with such problems because you will be dealing with a dealership and they will give you every excuse in the book if you dont bring it in asap.
and dont try to mess with the car either. forget VAG codes. go straight to the dealership. Its CPO, it should be covered. and worst comes to worse, you will only pay $50 deductible. so save yourself a lot of **** down the road and head for the dealership now.
ahh.. whats the fun in that? do some research, get the code pulled from autozone or advance, list them on here and see what you come up with. you might just learn something and you may not have to deal with the dealership yankin your chain...
well his car is still under warranty since he mentioned it is CPO. fun? not when you are spending more than the $50 deductible. i'd be all for the DIY if it wasnt under warranty anymore. but that just isnt the case here.
Okay, it turns out that it's some sort of intake vacuum thingie. I went slightly deaf when he said something about 3-4 hour job. It's not critical, so I'm going back to the dealership when I have time (and my laptop to do work) next week. At least they have free coffee and Snapple there.
Thanks for the advice...as much as I'm a DIYer, I also don't want to mess with CPO.
By the way, when I was at the dealership today, I saw a new A4 Avant (sexy), and A5 (sexier), and a couple of new-ish RS4 sedans (sexiest!).
Cheers,
john
Cheers,
john
