Clearing VAG codes question
Old Oct 16, 2007 | 02:10 PM
bpguitarbiker's Avatar
Default Clearing VAG codes question
I got a VAG code that indicated a brake pressure sensor problem. I made a few adjustments and want to see if it solved the problem. Am I right to assume that I can clear out the code and if it is still a problem the code will reappear after some driving.
Thanks
Old Oct 16, 2007 | 02:43 PM
techbod's Avatar
Default RE: Clearing VAG codes question
the code would be nice, just clearing it doesn't solve it the code is just a guide to the problem
Old Oct 17, 2007 | 08:01 AM
The code was 01435 which is for a brake pressure sensor. I removed and cleaned the wheel speed sensors and cleaned up the brake area which the book recommended as possible causes. Next I was thinking of clearing the code with my VAG reader. What I'm wondering is if I clear the code, will the code come back if the issue wasn't fixed by my cleaning work. And then I would take the next step to resolve the problem like addressing the brake pedal switch which is also a possible cause.
Old Oct 17, 2007 | 10:26 AM
techbod's Avatar
nothing like it on my codes and is there such a thing as a break pressure sensor? Ive never heard of it, are you reading the fault code correctly? 01435 doesn't exist or is it P1435 which is secondary air injection (air) pump relay - short to ground
Old Oct 17, 2007 | 10:40 AM
01435 Brake pressure sender -G201
It was in my Bentley cd
Mainly I want to know if clearing the code will mean that it will reappear if the repair I performed didn't work, and won't reappear if the repair did work.
Old Oct 17, 2007 | 10:52 AM
techbod's Avatar
hmm interesting so it must be a chassis code which I don't have but not to worry and yes if you clear the code and it doesn't come back there is no problem
Old Oct 17, 2007 | 10:59 AM
techbod's Avatar
Removing and installing brake pressure sender1 -G201-
Removing
Note[/align]
Cover the engine compartment to ensure that no brake fluid flows into it.
Loosen securing bolt - 1 - and pull the coolant expansion tank out in direction of arrow, then swivel tank to one side.
Tightening torque: 6 Nm
Unplug connectors -1-.
Unscrew brake pressure sender -4-.
Installing
Remaining installation steps are carried out in reverse sequence.
Bleed brake system.
[IMG]local://upfiles/12092/D260D0EB8D9345A68673ED66AD92652B.jpg[/IMG]
[IMG]local://upfiles/12092/DF026AE43BF94B779E9F4E248BE5F688.jpg[/IMG]
[IMG]local://upfiles/12092/7822A541174D46B69AA8A7EC2DFECA04.jpg[/IMG]
Old Oct 17, 2007 | 11:01 AM
Thanks a bunch
97prelude
Aug 25, 2023 10:06 AM
freakaftr8
Mar 11, 2009 05:47 PM
morrisonjd84
Oct 23, 2007 11:19 PM
greenavant
Jul 20, 2007 05:50 PM
mainer
Mar 13, 2005 10:14 PM
