coded message
Old 07-19-2007, 02:43 PM
doctorball's Avatar
Default coded message
I have acode display on my dash, it appears soon after I start driving, 1997 A8, I don't have a manual...it is a circle with nothing in the middle and 3 small lines on each side conforming around the circle, I will try to post a pic...can anyone tell me what this is?
Old 07-19-2007, 02:48 PM
kingtut's Avatar
Default RE: coded message
brake pads I believe
Old 07-19-2007, 03:06 PM
doctorball's Avatar
I was thinking that, but unsure...I checked all the brake pads, fronts have a good amount left, except the rotors have criss cross pattern developed on them...back have about 50%...I was thinking of changing out the front rotors to sloted/drilled with different brake pads...
Old 07-19-2007, 03:12 PM
kingtut's Avatar
Mine as well! That's one mistake I made, was replacing the roders with OEM, instead of upgrading. Plus, I should've looked into the low dust emitting pads that I hear about. Actually, I've heard that the code you have only comes on when your pads are super worn, could be wrong though-
Old 07-19-2007, 05:04 PM
SAudi's Avatar
it could be that the sensor for the pads failed.
scottevans
02-05-2015 01:25 PM
coloradoA8
05-12-2014 10:28 PM
GWerks
05-04-2011 10:54 PM
Boostfed13
06-05-2008 09:36 PM
charcormier
03-27-2007 03:40 AM
Quick Reply: coded message
