Coolant issue! Sludge? Leak?
Hi all,
I have a problem with my coolant in my A4 B6 1.8t Quattro.
A couple of days ago the coolant light came on warning me that I had low coolant. It was fairly intermittent and it would only come on when I parked on a hill so it was just a tiny bit low. Anyway, I topped it up with some Comma Xstream G30 Antifreeze & Coolant and the light went off completely, so I thought all was well.
However yesterday the vents stopped giving out warm air altogether, and so I suspected something. Today I had a coolant warning that would not go away and when I checked the reservoir It was completely empty.
I had no choice but to drive home, the vehicle did not overheat at all and the vents gave out warm air at idle revs, and when I checked the coolant level once home it was low, but the reservoir was no longer completely empty.
Any ideas? I read that mixing two incompatible coolants can cause a sludge to form, could this have been the issue? Could there be a leak or air blockage? What's the best course of action?
Cheers guys
Cheers guys
I'm having the same problem with my 02 a4. I have all your symptoms plus milky looking substance that i noticed on the dipstick, none on the oil cap. I've beem researching on it and its possibly a bad cylinder head? It ran fine with no overheating before i parked it.
Yours seems like a much more serious problem, I haven't experienced it but I think it is either a leaking head gasket or a leak at some other part of the system. That needs repairing immediately if that is the case.
Hope you get it sorted pal, cheers for your input!
Cioffie
May 19, 2013 10:24 PM
JETSPEED333
Aug 15, 2008 06:25 PM
