cam seals and oil sludge/leak...
Old Jun 22, 2008 | 05:12 PM
410ThirtyValve's Avatar
Default cam seals and oil sludge/leak...
I was recently working under the hood (tb job) and decided to forego a cam seal replacement job although I had the 4 brand new seals and access to the shafts. Now I am a little concerned b/c I know that the seals are related to the common oil sludge problem with these cars. Just wondering around when- what mileage- this sludge problem usually occurs and how often? what is the potential damage caused? I haven't had any leaks or problems yet, but was rather going to do it as a precaution since I was already in there...just turned out to be more than I was willing to handle at the time. Thanks again, for any help.
Old Jun 22, 2008 | 05:37 PM
austindgarner's Avatar
Default RE: cam seals and oil sludge/leak...
I think that the sludge problem can occur anytime if you don't take care of your engine. You should have a problem with sludge if you use fully synthetic oil because it does not break down.
Old Jun 22, 2008 | 05:45 PM
thanks good to know...fully synth all the way
Old Jun 22, 2008 | 05:55 PM
hiwords's Avatar
sludge doesn't suddenly occur. like austin said, it depends on how you take care of your car. seafoaming your car, using a big filter and frequent oil changes will reduce sludge problems though. sludge usually isn't a problem with the 2.8 though. o and there's a PES supercharger for sale that someone posted up from craigslists.
Old Jun 22, 2008 | 06:49 PM
Yeah I saw the post for the supercharger but I am not sure about the difference between the G1 and G2 (I plan on getting the G2); more importantly, I probably can't afford it yet.
Thanks for the info tho. I thought seafoaming wasn't too good for your car?
Old Jun 23, 2008 | 08:49 AM
I did a search/research on seafoaming and I think I will do it right before my next oil change this August/September. I will probably try and do it about every other oil change from onow on, which would be every ~24000 kilometers. Sounds good?
Old Jun 23, 2008 | 04:47 PM
david9999's Avatar
Synthetic oil will be fine for 7500 miles. Just make sure that you don't let your oil level go low.
gerroffme
Mar 9, 2014 10:22 AM
Asianicestyles
Jul 17, 2008 01:26 AM
car928
Mar 8, 2008 06:30 PM
dragondesigns
Mar 14, 2006 02:38 PM
