Cooling Fan only running on High
Old Jun 9, 2011 | 11:44 AM
LKaler's Avatar
Default Cooling Fan only running on High
Hi everyone,
I recently noticed that my fans on my 1.8t TT are running only on high. Even with the AC is on, the fans do not kick in until the engine heats up and when they do they are only on high for a limited amount of time. Also when i turn the car on initially, they kick on high for about 5 seconds, then they turn off and then kick back on high for 5 more seconds. I am leaning toward the fan control module, since they are getting power, and do function on high. Does the coolant fan switch control both speeds of the fan? If it is just the low that may be something I need to look into as well. Anyone have any insight on this? Thanks
Old Jun 9, 2011 | 01:25 PM
LKaler's Avatar
UPDATE:
I pulled the #16 Fuse, and no fans still. It is my understanding, that if the module was working correctly, pulling that fuse would engage both fans when the ignition was on. Also, I forgot to mention, I recently replaced the small radiator fan which was faulty. Could the new fan put enough load on the module to push it over the edge?
vtraudt
Nov 2, 2012 09:50 AM
a4blk
Dec 12, 2010 11:12 AM
jhuffman
Mar 9, 2010 10:18 PM
TURBOJEDI
Nov 7, 2009 02:06 PM
profects4
Mar 25, 2008 06:42 PM
