High performance cooling
On my list of things that scares me about cars its overheating. My ride runs just fine as of current with a totally new cooling system (water p, aux p, theromostat and housing, fan blade). I want to further augment this by working to create a high performance cooling system for my car. Here what I have in mind. New High flow electric fans (considering replacing the mechanical one with electric) for the radiator and condensers, possibly seeing if I can get 2 mounted there up front since I will be installing a FMIC. I also want to shield my entire intake system with aluminum and insulation. Thoughts?
oh, also I plan to replace my coolant temp sensor with the green topper because I have the black one and also the thermo switch for the after run system, maybe I could wire the fans into that system as well.
I just looked into this and wanted some thoughts on it. There were some guys on a benz board who are heat wrapping thier intakes and showing a definite temp decrease. What if I wrapped heat reflectors around the intake and other intake tubes. Thoughts?
I remember reading somewhere that for every 10 degrees celsius (maybe Fahrenheit???) you can drop the IAT, you will see approximately 1% increase is total horsepower. Anyone else heard this? I would think that a good reflector wrapping coupled with a FMIC would provide a great drop in temp, especially here in Denver at this crazy altitude.
A better oil cooler is definitely included in this setup. I want the VAST upgrade, and a high capacity oil filter. I have also considered finding a way to run one oil cooler into another oil cooler since they are teeny tiny and I am totally paranoid about overheating issues lol. I feel stupid for asking this but I have heard of sandwiching oil coolers but I've never heard or seen a good direct description of what this is. Being enlightened would be much appriciated.
