CV Boot replace
Old Apr 13, 2008 | 09:10 AM
Albee G's Avatar
Default CV Boot replace
Gentlemen,
Have any of you fellas changed a front outer CV joint boot on a 2002 A8 and if so is there a workaround for the "special tool" needed to press off the CV joint? Seems to me the procedure is fairly straight forward except fot the need for BILLIONS of special tools.
I like doing some of my own work but the need for all these tools is getting a bit out of hand. Any suggestions?
Thanks,
AlbeeG
Old Apr 13, 2008 | 06:11 PM
KevinV10's Avatar
Default RE: CV Boot replace
yeah. you can do it without special tools. basically just hit it out with ahammer. just try not to mushroom the axle end.
Old Apr 13, 2008 | 06:39 PM
tHe kNiGHt FaLL's Avatar
when the axle is free of the spindle... screw the axle bolt back in the end until is doesn't go anymore. we use an impact to drive it in. i never tried to using manual tools. it still should work.
from there the cv assembly will be free of the retaining clip... and then you can use a hammer to tap it off.
don't bang it w/ a hammer...
Old Apr 14, 2008 | 05:25 PM
Albee G's Avatar
Thanks guys.
Knight, I will be gentle with the hammer. Your saying that the bolt itself can be used as the puller? Cool.
thetryal
Mar 3, 2013 11:41 PM
KoolMan
Feb 27, 2013 11:37 PM
chickeneater
Dec 7, 2010 12:41 AM
what?
Oct 21, 2007 11:23 PM
ericmorin
Jul 10, 2005 02:28 AM
