Cylinder 2 misfire...please help:-(
Old Mar 29, 2007 | 01:00 AM
Honda882000's Avatar
Default Cylinder 2 misfire...please help:-(
Hello all,
I am currently having a misfire issue which I can't figure out. I actually received a warning signal a few days ago when the car felt like it was misfiring when I first turned it on, but only lasted for a few seconds. All of a sudden this afternoon after work, I turn on the car and it is clearly misfiring. The engine light turns on and I imediately drove to the close by autozone to get the code checked. The code was for cylinder 2 misfire, so I simply think its a coil and go home. After changing the coil, same issue still occurs. I even tried with another coil, just in the unlikely case the new coil was broken, and its still not working. Could this be a computer issue? I bought the car with an APR chip, so that came to my mind. Any ideas? I also checked voltage to the lead of the coil wire and it has 11.5v.
Thank you very much for your help.
Old Mar 29, 2007 | 12:16 PM
frostyduke's Avatar
Default RE: Cylinder 2 misfire...please help:-(
What model do you have ? My is a 2006 A6 and experiencing the same problems. Only 11000 miles on it. It missfires but after a while it returns to normal. Drive it for a few hundred miles and the same crap happens again. Dealer is havinga hard time figuring this one out.
Old Mar 29, 2007 | 03:04 PM
GeilKyle2's Avatar
Sounds like ignition control module has possibly failed?
Old Mar 29, 2007 | 03:17 PM
2k S4's Avatar
Swap the #2 coil to another cylinder & also swap around the plugs, & see if the MF moved to that cylinder.
You might as well change the plugs while your messing around.
Old Mar 31, 2007 | 01:57 PM
frostyduke's Avatar
Dealer updated Engine Control Programming per Bulletin 2010890/3
So far so good! Only time will tell if they got it right.
Old Mar 31, 2007 | 02:01 PM
frostyduke's Avatar
Dealer updated the software on the Engine Control per Bullentin 2010890/3 on my 2006 A6
So far so good, only time will tell.
Russ Heinrichs
Aug 18, 2021 12:39 PM
and b
Feb 10, 2014 11:52 AM
ThePizza
Jul 23, 2008 05:16 PM
ricky0323
Feb 29, 2008 01:35 PM
