Disabling Headlight Washers
I just got a 02 a4 1.8t....I noticed a very small amount of washer fluid in the garge on the front passenger side. I took out the headlight and can see the headlight washer pump is the problem. After reading a lot of posts on this I think I'd rather just disable the headlight washer system altogether. Sounds like they cause a lot of problems and I could live without it. What's the easiest way to do this?
Thanks a million.
Thanks a million.
I don't have teh manual for you specific vehicle, as I drive an A8, but, your vehicles manual should tell you which fuse goes to what vehicle function. Check it out and see if the fuse for teh headlight washers ONLY covers teh headlight washers. I'm fairly certain that is teh case. If you do not have your manual, or if you're still not sure, take a moment to post in the A4 section. I'm 100% certain someone there WILL know, and share taht information with you.
According to my program, the fuse that is used for the headlamp washer is the same as the fuse for the windshield washer. Your best bet would be to unhook the washer pump.
I attached a image of where the reservior is. Hope it helps
[IMG]local://upfiles/27174/3D29B39E0B3B4A38905672B89A3CFF08.gif[/IMG]
You should be able to see it from underneeth the car. Its near the bottom of the reservoir at the front. Just follow the hose from the headlamp washers to the reservoir and thats your pump.
There may be a clip, or clamp, of somr sort, holding it in place. DEon't pull harder untill yiou've poked/peeked/felt around/above/under the thingy (<--technical term) to determine what's holding it in place so firmly. Get yersel;f one of those tiny little LED flashlights to see better with...
