disappearing coolant?
Old Jul 16, 2007 | 06:41 PM
solrac's Avatar
Default disappearing coolant?
97 A4--says coolant is low...add some then when it is shut off...it will leak from the overflow. It never looks like there's enough in there but if you add, it will come out the overflow after shutdown. I do hear aslight gurgling noise in the dash. I've just had the cooler replaced. Any suggestions?
Old Jul 17, 2007 | 05:18 PM
rbrtech's Avatar
Default RE: disappearing coolant?
air pockets. but are you overfilling or is the level actualy low in the fill bottle
Old Jul 17, 2007 | 05:23 PM
techbod's Avatar
the cooler? I assume you mean the heater matrix or the radiator ^defiantly air in the system^ ensure you have the heat turned to max so it bleeds the matrix as well as the engine and radiator
Old Jul 17, 2007 | 05:26 PM
rbrtech's Avatar
not real sure what he means either could be the heater core he was meaning
Wasteland
Feb 24, 2014 06:33 PM
dean132
Feb 16, 2011 01:07 PM
201Concepts
Sep 12, 2008 02:49 PM
brodieone
Dec 13, 2007 07:53 PM
3phil4
Mar 8, 2007 08:46 PM
