Engine oil level low light
Old Jun 5, 2013 | 11:38 AM
Sunset's Avatar
Default Engine oil level low light
Hello,
I have a 2003 A4 3.0 quatro, this oil level light has turned on and i still have 3000 more miles to go before I'm due for an oil change... i went to an auto parts which they check my oil and they said i needed a 5w30 synthetic oil so i purchase the best which they recommended Castrol! once i put the oil in the light went off for about 24hrs then it turned on again so i put another bottle! went off and now is on again! i have tripled check the car and i don't have any spots of loosing oil... can someone give me some directions? is getting sooo frustrating.. also i just got change an ECT sensor and i wonder if this got something to do with it... PLEASE HELP! LOL A CHICK WITH NOOOO KNOWLEDGE
Thanks =)
Old Jun 5, 2013 | 08:52 PM
cas5259's Avatar
Your oil level sensor probably went bad. It is on the bottom of the oil pan so it's easy to get to when you change your oil in 3k. Get the OEM replacement if you can. I bought a cheap aftermarket one, which only worked for a few weeks before giving the same errors as the old sensor. Ended up buying the Audi one after that.
In the meantime, check on your oil level often to make sure there is enough in there.
Old Jun 6, 2013 | 08:22 AM
Sunset's Avatar
ok great!!! thanks for the reply.... i was hoping it was something simple.... I wonder why is giving me the low oil warning light and not the sensor one.
Old Jun 6, 2013 | 11:48 AM
cas5259's Avatar
Does the light say "sensor" next to the oil symbol? Also, if its a bad sensor but the computer thinks its fine, than of course it will not read right!
Old Jun 7, 2013 | 09:40 AM
Sunset's Avatar
no it says MIN next to it... but the mechanic said yest according to the code that it is the sensor that's in the oil pan.... all of that is Chinese to me so i just said ok lol
rfoulkes
Feb 16, 2015 01:13 PM
SMITHEREENZ
Jul 23, 2011 09:43 PM
Yale
B7 Models
18
Jun 29, 2009 03:21 AM
TripN
Aug 19, 2005 06:03 PM
