Engine Oil Type
Old Sep 5, 2006 | 12:51 AM
Deekster22's Avatar
Default Engine Oil Type
I'm about to do an oil change on a 2000 Audi A6 2.8L. What type of oil should I use? Synthetic or conventional? Weight? I live in central NY if that makes a difference.
Old Sep 5, 2006 | 01:55 AM
Bondga's Avatar
Default RE: Engine Oil Type
Full synthetic 5w-30
Old Sep 5, 2006 | 12:02 PM
CRAZYHAWK's Avatar
Old Sep 5, 2006 | 06:13 PM
kakarot's Avatar
I use Mobil 1 0w-40 I have 1995 V6 audi 90.
read my article, located on my homepage.
Old Sep 15, 2006 | 02:30 AM
a6xlr8s's Avatar
Fully Synthetic! Mobile makes 0w-30 for european cars. 5W-30 is also fine overall. Living in NY does make a differance because you are exposed to cold weather. That's what the first number is about. 0w or 5w are extreamly thin at start up for the high tech tight spec 30v engine you have. If the car is high in miles and has had a diet of conventional oil I would stay conventional as to not start freeing up deposits left over time.
Old Jun 18, 2007 | 04:27 PM
pimptrooper3000's Avatar
i have a 98 1.8t and i really don't like my oil, i use a chevron 10w-30...i am changing it this weekend and i don't know what to put in...help
Old Jun 18, 2007 | 04:32 PM
techbod's Avatar
chevron 10w-30 yuk that's conventional as low as you can get 0w/30 or 0w/40 minimum full synthetic or the lowest of the low for these cars is semi synthetic 05w/30
Old Jun 18, 2007 | 06:07 PM
CRAZYHAWK's Avatar
Castrol, Castrol Syntec 5W-40
Chevron, Chevron Supreme Synthetic 5W-40
Elf, Elf Excellium LDX 5W-40
Kendall, Kendall GT-1 Full Synthetic Motor Oil 5W-40
Mobil, Mobil 1 0W-40
Pennzoil-Quaker State, Pennzoil Synthetic European Formula 5W-40
Pennzoil-Quaker State, Pennzoil Synthetic European Formula Ultra 5W-30
Pennzoil-Quaker State, Quaker State Full Synthetic European Formula 5W-40
Pennzoil Quaker State, Quaker State Full Synthetic European Formula Ultra 5W-30
Seventysix Lubricants, 76 Pure Synthetic Motor Oil 5W-40
Texaco, Havoline Synthetic 5W-40
Total, Total Quartz 9000 5W-40
Valvoline, Valvoline Synpower 5W-30
Valvoline, Valvoline synpower 5W-30
Old Jun 18, 2007 | 06:17 PM
techbod's Avatar
only 0w means full synthetic anything with a number above 0w is semi synthetic
Old Jun 19, 2007 | 10:35 AM
CRAZYHAWK's Avatar
