Engine stutters when accelerating hard
Old Nov 23, 2012 | 06:20 PM
judgejules95's Avatar
Default Engine stutters when accelerating hard
I have an A4 1.8T 2007 55k manual
It had the timing belt and service a couple of months ago
Normal driving is fine but when I press hard on accelerator (low or high revs) it tends to stutter but only when the engine has warmed.
Usually in 2/3 gears
No warning lights
I have taken the plugs out and cleaned them but hasn't helped
Ideas please!!!
Old Nov 27, 2012 | 12:18 AM
3star2nr's Avatar
I wanted to post a reply but i cant yet.
Anyway your problem doesnt sound very complex, if you just did the timing chances are a sensor was incorrectly installed. I'd start by checking the throttle position sensor.
If the car is bogging under acceleration and only when warmed up it means your problem only happens when the engine switches to its closed loop cycle. A bad or not properly connected sensor such as TPS, mass airflow or O2 sensor will cause this problem.
Since you have no warning lights vacuum leaks, behind your Airflow sensor. may also be a source of your problems,
So to recap in order of most probable to least probable:
1. Faulty installed sensors: Check that all your sensors are properly plugged in
2. Check that the TPS and crank angle and cam angle sensors are properly installed
3. Vacuum Leak, check the EGR, PCV valve etc
4. Spark related: Your car doesnt use a distributor, so the only logical ignition problem has to be in the coil packs, spark plugs or the ignition amplifier or PTU I dont know what they call it on audis but its usually a seperate controller that takes the signal from the ecu and sends it to the coils, the coils then fire.
5. Improperly installed or fouled Spark plugs: Check your plug gaps, a gap two wide will cause missfiring, but it should occur at all times, if its a plug issue
6. Fuel issue (this is unlikely)
Good luck friend
Other sources of problems:
http://www.bba-reman.com/content.asp...speed_problems
Old Nov 29, 2012 | 12:18 PM
Thanks for this, what sort of costs am I looking at? I Go to Audi specialist, not main dealer
1. Faulty installed sensors?
2. Check that the TPS and crank angle and cam angle sensors are properly installed?
3. Vacuum Leak
4. Spark related: coil packs, spark plugs or the ignition amplifier or PTU?
Thanks again
rashby77
Jan 29, 2015 01:54 AM
jcc2k4
Apr 5, 2009 05:38 PM
nick_goldie
Sep 9, 2008 12:36 AM
huyaroo
Sep 12, 2007 03:37 PM
