EPS fault code 08 Audi A6 3.2
I had this fault code come up after my dad clicked reset wheel alignment on his scanner. Does anyone know why this happened or how to reset it? It comes on after driving a few minutes. It’s never there in startup and won’t go off once it faults.
I also had these codes come up lately if you know anything about them:
04440 manifold pressure sensor g71(p1158) implausible signal short with ground intermittent
00104 map/maf throttle position correlation p0068 short with ground intermittent
08304 intake manifold tuning valve bank 1 stuck open p2070 short with power intermittent
it’s a modi’s ultra scanner idk if that’s needed...
Also steering wheel has play ,about a fingernail most(is there a sensor for this),but all the joints and control arms etc are good and pulls to the right and travels a little even after alightnments even
