ESP problem
Old May 15, 2008 | 05:39 AM
accswb's Avatar
Default ESP problem
Hi, i have just bought a O2 audi a4 and seem to have a problem with it cutting out when at low revs in low gears , the ESP light comes on and it cuts out. restart it and off it goes again no bother, very annoying though. any ideas what could be the problem???
cheers stuart
Old May 15, 2008 | 09:07 AM
CRAZYHAWK's Avatar
Default RE: ESP problem
If the ESP light flashes, it is applying individual
brakes to control under or over steer.
Old May 23, 2008 | 06:00 PM
MGarage1126's Avatar
I had a similiar problem with my 2001 s4. The ESP light would stay illuminated and then cut back out after a period of time. The system is based on the traction control of the car. If it flashes vigorously then it should be working properly. In my case the light was solid and the problem was actually my MAF sensor. Considering this sensor measures load on the car, a fault in the system would mis-calculate and throw thelight because the VSS would not be valid either.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
