Front end tapping
Old Mar 16, 2007 | 08:16 PM
2wrds4u's Avatar
Default Front end tapping
Problem #2 with my '95 Cab (first was a leak in the expansion tank under the main gas tank) I just noticed today a tapping in the driver side front end. It is a rapid tapping I notice when I first start the car. After a little while it stops and then starts again. Any idea what it can be? I appreciate the help...this is my first Audi and my first used car, so I'm a little on the nervous side!
Old Mar 17, 2007 | 12:34 AM
AWDaholic's Avatar
Senior Administrator
Default RE: Front end tapping
knowing the engine size sometimes helps us diagnose engine noises
Old Mar 17, 2007 | 04:51 AM
Flip's Avatar
If it only does it when it is cold it could be your bearings needing time to warm up, rod knock or lifter tick. It is hard to say without hearing it in person.
Old Mar 17, 2007 | 02:00 PM
2wrds4u's Avatar
The engine is a 2.8 V6. Oddly, it is bitterly cold this morning and I'm not hearing the noise (which after reading some other posts, I should describe as sounding like a helicopter. I was wondering if the dealer (where I took it yesterday) possible loosened something while trying to identify where the gas smell was coming from. They finally determined that the expansion tank was leaking by removing the main gas tank and examining the expansion tank which is apprently under the back seat. Sound feasible?
Old Mar 20, 2007 | 02:00 AM
Whiplash's Avatar
If it sounds like a diesel then its most likely lifter tick. Check your oil...
AliciaVR6
Mar 6, 2014 02:35 AM
drh784
Aug 17, 2007 12:16 AM
B Audi
Mar 11, 2007 02:29 PM
JKeppelman
Nov 4, 2006 01:37 AM
nexus6
Feb 20, 2006 07:15 PM
