FSI injector seals
Old Jul 26, 2016 | 06:05 PM
drexer31's Avatar
Default FSI injector seals
Hello everyone,
my 2007 Q7 4.2 has had a misfire problem for a while now. I have had the dealer try to diagnose it and I feel like their just throwing parts at it, and its not fixing the problem. It has 110k on it and it have never had a carbon cleaning so i'm going to clean the valves this weekend and see if that fixes it. My question is does anyone know if there is a way to check the injector seals? It would be nice to know if I need to replace any of the seals while the intake is off so I don't end up pulling it a second time.
Old Jul 27, 2016 | 07:19 AM
dave944's Avatar
If you had a leaky injector seal, you would get an OBD code indicating a "lean" condition. I had a misfire issue a couple of years ago that turned out to be crappy spark plugs. One or two had "glazed". If you're getting the misfire on acceleration, that could very well be the issue.
Check out my post about it from a while back. https://www.audiforums.com/forum/gen...k-plug-218806/
Old Jul 27, 2016 | 12:51 PM
drexer31's Avatar
Thank you Dave that is very helpful.
I don't have a lean condition code just misfire codes on 6 of the 8 cylinders and a random misfire code.
I guess I should have included all that stuff the dealer has done so far to try to clear up the problem. So far they have;
-ran some sort of cleaner through it to clean the carbon
-Replaced an intake runner solenoid.
-Replaced the in tank fuel pump and filter.
All to the tune of about 2600.00 and honestly the car have never ran worse.
I usually do all my own wrenching but I've been extremely busy at work lately.
When I bought the car I replaced the plugs with oem Ill pull them and check to see if their glazed as you suggested.
Ill check the codes one more time before I tear into it and be sure there is not a lean condition code. if I still don't have one then Ill leave the injector seals alone.
Old Jul 27, 2016 | 01:03 PM
drexer31's Avatar
When I bought the car I replaced the plugs with oem and have since tested all the coils.
Old Jul 28, 2016 | 07:17 AM
dave944's Avatar
I spent $600 on various parts including a new fuel pump. Of course that would have been $2000 worth of labor if I had to pay someone else to do it. Turned out to be 2 glazed plugs.... They were relatively new, just a few months old. I had an O2 sensor issue on that side (bank 2) previously. I think that is what caused the heat condition that glazed them.
skateboy918
Oct 15, 2013 11:58 AM
Pitao
Sep 18, 2013 09:59 PM
JhonQ
Jul 11, 2013 06:41 PM
gwos25
Nov 10, 2009 01:08 PM
DarkHelmet
Dec 20, 2004 03:02 AM
