GTRS Install - check engine light
I installed ATP's GTRS turbo kit (turbo,manifold,3' downpipe)on my 1999.5 A4. For fueling I bought the Mika tune. I got a check engine light on the start up. The car also dies down whenever the turbo starts to boost.
I only reinserted the MAF sesnsor in the intake piping. Code exlcuding the other sensors cause theissues that I mentioned above?
Stretch
Stretch
One of the codes was cylinder misfire. The other one I couldn't find a definition for: It's P1613. The car is running really lean. It idles at 18 to 1 fuel ratio, and is around 13 to 14 on throttle.
Thnx for the reply. I appreciate it.
ORIGINAL: Stretch1.
Thnx for the info. We shouldn't take this setting down. It's inexcusable that they're selling a product that will cause catastrophic failurewhile being used as intended. There is no industry that you can get away with this. This is truly the definition of a faulty product, and as such should be fully refundable.
I put the stock MAF back on the car and now it's running rich. The car isn't cutting out anymore, and seems to have stopped shutting off while coming to a stop.
parlayin
Feb 10, 2010 12:33 PM
RyanSweeney
Jan 20, 2009 02:15 AM
